error "Render to File"
Posted: Thu Jun 13, 2024 8:13 am
by fbp
I think there is a problem with the graphic scale that is generated when the "Render to File" command is executed.
I am obtaining vertical sections of a model and when saving the frontal capture I do not get a scale elevation. In the image obtained, the measurement that appears is exactly 25% larger than the corresponding one (for 4 m a graphic scale of 5 m appears, and for 8 m it appears 10 m), do you know if there is any error?
CloudCompare Kharkiv version 2.13.1
Re: error "Render to File"
Posted: Thu Jun 13, 2024 6:22 pm
Did you use a 'zoom' factor maybe? And was the projection mode 'orthographic' or 'projective'?
Posted: Fri Jun 14, 2024 12:10 pm
by fbp
The system used is orthographic with an adequate zoom to obtain the necessary resolution
Posted: Tue Jun 18, 2024 8:51 pm
Sorry for the late reaction, I was travelling.
I'll have to try to reproduce this issue on my side first...
Posted: Wed Jun 19, 2024 12:50 pm
by fbp
Thanks for the comunication.
I have reviewed the problem and it seems that it is motivated by the size of the graphic scale, the image shows a value one meter higher than the corresponding one, thus for 4 m it appears 5 m (25% larger).
Posted: Sun Jun 23, 2024 1:09 pm
Hum, I think I've managed to reproduce it. This seem to only happen when the height of the screen is higher than the width.
Posted: Sun Jun 23, 2024 3:44 pm
Ok, this should be fixed in the next 2.13.2 release. You can find the preview here: https://www.cloudcompare.org/release/Cl ... up_x64.exe
