Saved bin file won't open
Posted: Thu Jun 13, 2024 3:55 pm
by FiguringItOut
I had a fairly large project, and wanted to split it up into smaller entities. I saved different bin files for the exterior, interior, and surrounding landscape of the building. I actually did this two separate times, as I made some edits after saving the first time, but saved in a different location. In both locations. The exterior.bin file won't open back up in CloudCompare. Task manager shows that it loads up to 28,271.5 kb in the memory each time I try to load it, from both the GUI and from the command line, but just continues to say it is loading and never opens. Any help? Is there a way to extract the individual entities within the bin file without having to load the whole thing? Is there a way to figure out what is causing this issue?
I have the original e57, but put a lot of work into cleaning making the visualizations and don't want to have to redo everything!
Thanks in advance!
Re: Saved bin file won't open
Posted: Thu Jun 13, 2024 6:23 pm
Maybe the file was corrupted during saving... Would you be able to share it with me maybe? (admin@cloudcompare.org)
