measuring points from the TLS/GBL centre
Posted: Fri Nov 15, 2024 1:55 pm
by kyleramseyrca
Hi there, looking to measure points from the LiDAR sensors origin, but can't get my head around changing the pointcloud's centre/origin to the centre found on the TLS/GBL, then using point picking to get the x,y,x values of the point from the TLS/GBL centre.
Was wondering if anyone has done anything similar and got any tips?
Re: measuring points from the TLS/GBL centre
Posted: Sun Nov 17, 2024 8:29 am
Normally, if it's only the origin, you should be able to select the sensor entity, use 'Edit > Sensor > Edit' and the read/copy its center ('C' row = Cx Cy Cz).
Then use the 'Edit > Apply transformation' tool and pate the opposite values in the 'Translation' fields of the second tab (Axis, Angle). Translation = "-Cx -Cy -Cz"
And you can double check that it worked by looking again at the sensor parameters (Edit > Sensor > Edit). The center should be now at 0, 0, 0.
