Custom lighting
Re: Custom lighting
Then maybe the light is very far below the object? Have you tried to zoom out a lot?
Otherwise if the light source was inside the object, you would just have to hide the object to see it...
reflintorm
Re: Custom lighting
Post by reflintorm »
Sometimes the appers of the light will not be seen because the far distance in between of light and object.
Re: Custom lighting
Indeed. Do you know you can move it? (with CTRL key pressed and the right mouse button pressed)
