how to export OBJ
kelly1151
how to export OBJ
Post by kelly1151 »
Could you tell me how to save point cloud data as obj format?
According to CloudCompare User Manual for version 2.1, it looks you can export as obj.
I am using CloudCompare v2.5.4.1
I can import obj, but cannot export as obj. It seems there is not obj in the dropdown list to save the file.
If I can export obj, I can import the file into IRONCAD.
Thank you in advance.
Re: how to export OBJ
Well you should only select the mesh (warning: select the mesh entity and not its container) then 'File > Save as'...
kelly1151
Post by kelly1151 »
You are right, thank you daniel.
