CloudCompare 3D entities
Public Member Functions | Static Public Member Functions | Protected Attributes | List of all members
ccWaveform Class Reference
Waveform. More...
#include <ccWaveform.h>
Inheritance diagram for ccWaveform:
Inheritance graph
[legend]
Collaboration diagram for ccWaveform:
Collaboration graph
[legend]
 ccWaveform (uint8_t descriptorID=0)
 Default constructor.
 ~ccWaveform () override=default
 Destructor.
uint8_t descriptorID () const
 Returns the associated descriptor (ID) More...
void setDescriptorID (uint8_t id)
 Sets the associated descriptor (ID)
void setDataDescription (uint64_t dataOffset, uint32_t byteCount)
 Describes the waveform data.
uint32_t getRawSample (uint32_t i, const WaveformDescriptor &descriptor, const uint8_t *dataStorage) const
 Returns the (raw) value of a given sample.
double getSample (uint32_t i, const WaveformDescriptor &descriptor, const uint8_t *dataStorage) const
 Returns the (real) value of a given sample (in volts)
double getRange (double &minVal, double &maxVal, const WaveformDescriptor &descriptor, const uint8_t *dataStorage) const
 Returns the range of (real) samples.
bool decodeSamples (std::vector< double > &values, const WaveformDescriptor &descriptor, const uint8_t *dataStorage) const
 Decodes the samples and store them in a vector.
bool toASCII (const QString &filename, const WaveformDescriptor &descriptor, const uint8_t *dataStorage) const
 Exports (real) samples to an ASCII file.
CCVector3 getSamplePos (float i, const CCVector3 &P0, const WaveformDescriptor &descriptor) const
 Returns the sample position in 3D.
uint32_t byteCount () const
 Returns the number of allocated bytes.
uint64_t dataOffset () const
 Returns the byte offset to waveform data.
void setDataOffset (uint64_t offset)
 Sets the byte offset to waveform data.
const uint8_t * data (const uint8_t *dataStorage) const
 Gives access to the internal data.
void setBeamDir (const CCVector3f &dir)
 Sets the beam direction.
const CCVector3f & beamDir () const
 Returns the beam direction.
void setEchoTime_ps (float time_ps)
 Set the echo time (in picoseconds)
float echoTime_ps () const
 Returns the echo time (in picoseconds)
void applyRigidTransformation (const ccGLMatrix &trans)
 Applies a rigid transformation (on the beam direction)
uint8_t returnIndex () const
 Returns the return index.
void setReturnIndex (uint8_t index)
 Sets the return index.
 Destructor.
static bool ToASCII (const QString &filename, std::vector< double > &values, uint32_t samplingRate_ps)
 Helper: exports a series of values as an ASCII file.
static bool WriteError ()
static bool ReadError ()
static bool MemoryError ()
static bool CorruptError ()
uint32_t m_byteCount
 Waveform packet size in bytes. More...
uint64_t m_dataOffset
 Byte offset to waveform data.
CCVector3f m_beamDir
 Laser beam direction. More...
float m_echoTime_ps
 Return Point location (in picoseconds) More...
uint8_t m_descriptorID
 Wave Packet descriptor index. More...
uint8_t m_returnIndex
 Return index.
Additional Inherited Members
Detailed Description
Waveform.
Warning
Waveforms do not own their data!
Member Function Documentation
◆ descriptorID()
uint8_t ccWaveform::descriptorID ( ) const
inline
Warning
A value of zero indicates that there is no associated waveform data.
◆ fromFile()
bool ccWaveform::fromFile ( QFile &  in,
short  dataVersion,
int  flags,
LoadedIDMap oldToNewIDMap
overridevirtual
Loads data from binary stream.
Parameters
ininput file (already opened)
dataVersionfile version
Returns
success
Reimplemented from ccSerializableObject.
◆ isSerializable()
bool ccWaveform::isSerializable ( ) const
inlineoverridevirtual
Returns whether object is serializable of not.
◆ toFile()
bool ccWaveform::toFile ( QFile &  out) const
overridevirtual
Saves data to binary stream.
Parameters
outoutput file (already opened)
Returns
success
Member Data Documentation
◆ m_beamDir
CCVector3f ccWaveform::m_beamDir
protected
Parametric line equation for extrapolating points along the associated waveform: X = X0 + X(t) Y = Y0 + Y(t) Z = Z0 + Z(t)
◆ m_byteCount
uint32_t ccWaveform::m_byteCount
protected
Warning
Not necessarily equal to the number of samples!
◆ m_descriptorID
uint8_t ccWaveform::m_descriptorID
protected
Warning
◆ m_echoTime_ps
float ccWaveform::m_echoTime_ps
protected
The offset in picoseconds from the first digitized value to the location within the waveform packet that the associated return pulse was detected.
