contour line and profile line
Posted: Fri Oct 11, 2013 1:15 am
by tsyxulei
Hi
Thanks for your provider this wonderful source .I want to create contour line and profile line Can you provide some advises?
Re: contour line and profile line
Posted: Fri Oct 11, 2013 7:08 am
For the moment, the only available tool is the "Point List Picking" tool (main toolbar) that let you pick several points then export this selection as a polyline.
But sadly you won't be able to export this polyline other than as a point cloud (i.e. a file with only the polyline vertices).
We hope to add one day:
- a mean to automatically extract contours (from slice obtained with the cross-section tool typically)
- a mean to export those contours to DXF (this one should be available soon)
Posted: Fri Oct 11, 2013 8:29 am
by tsyxulei
Thank you for your rapid reply .And I expect your contour tools release
