how to export OBJ
Posted: Tue Jul 15, 2014 6:31 am
by kelly1151
Could you tell me how to save point cloud data as obj format?
According to CloudCompare User Manual for version 2.1, it looks you can export as obj.
I am using CloudCompare v2.5.4.1
I can import obj, but cannot export as obj. It seems there is not obj in the dropdown list to save the file.
If I can export obj, I can import the file into IRONCAD.
Thank you in advance.
Re: how to export OBJ
Posted: Tue Jul 15, 2014 9:01 am
Well you should only select the mesh (warning: select the mesh entity and not its container) then 'File > Save as'...
Posted: Tue Jul 15, 2014 10:21 am
by kelly1151
You are right, thank you daniel.
